SOURCE: I am looking for an owner's manual for the Champion Elliptical
Did you find a manual? I have the same problem.
Thanks.
SOURCE: the program monitor on my eclipse 1100hr/a
After about 4 years, one day my monitor just wouldn't turn on. After making sure the batteries were new, I took out the four screws on the back of the monitor and made sure the two wire connections were tight. They were, so I called Fitness Quest customer service (1-800-321-9236) from their website (fitnessquest.com). For about $120 including shipping they sent me a new monitor. It took me about a minute to undo the old, plug in the new, and now it works great! The flat connection with the multi-colored wires requires a gentle squeeze with a pliers on the sides while you glently wiggle and pull it apart. Look at the new connector to see how it should come apart. Good luck!
SOURCE: tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email [email protected] they will help you they Tunturi Distributor of North America
SOURCE: My Reebok RL 1500 Elliptical console lights up but
Check the console if there is a small circle beside the connectors. I see this normally in XBOX, WII, or PS3. This is the reset button wherein you can press and hold this button using a toothpick...
SOURCE: 9500HR Elliptical console does not light-up
Please proceed according with the steps mentioned1
Remove
the bolts or screws securing the console to the upright assembly. Lift the
console and confirm that the cable connections are secure. Remove the cover
from the console's battery bay and install a fresh set of batteries. Replace
the battery cover. Detach
the ends of the pedals from the crank axles. Remove the left and right disc
shields and side shields. Inspect the interior of the base unit and locate the
flywheel. Inspect
the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the
flywheel until the magnet passes in front of the nearby reed switch. Loosen the
screw securing the switch in place. Rotate the switch to reduce the gap between
it and the magnet. Tighten the screw. Replace
the left and right disc shields and side shields. Reattach the ends of the
pedals to the crank axles.
Sincerely- G-d bless you
ernesto cuadra
managua,nicaragua
Treadmills have a moving belt while elliptical trainers have two foot pedals guiding movement - making it more controlled and safer. Elliptical trainers also have handles, in which the user has the option to move their arms in opposition to their legs to better control movement.
