Kitchen Ranges Logo
D
DAVID LITCHMAN Posted on Aug 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool oven not sure of the model. The burners can get red hot on a low setting. Do I have to replace the burners?
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Aug 01, 2018
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1261343
Points
17064
The burner is just a slave, your issue sounds like a controller matter. The burner cannot suddenly become hotter.
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 15, 2007
SOURCE: Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
A
Anonymous
  • Posted on Feb 19, 2008
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Anonymous
  • Posted on Sep 05, 2008
SOURCE: whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
Anonymous
  • 1136 Answers
  • Posted on May 27, 2009
SOURCE: whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Anonymous
  • 5911 Answers
  • Posted on Aug 02, 2009
SOURCE: stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
2answers
Gas valve wont open in my oven
This may be of some help
in most gas ovens you need to establish the pilot flame first before it allows gas through to the main oven thermostat,
The pilot can be part of the main burner /low flame that heats a sensor that is set to be heated by the pilot flame and as long as it stays red/hot it will hold gas on (flame proving device) and allow gas through to main flame. if you look at the main burner you should see the sensor its got a white porcelain base and the sensor is steel looks like a bent nail that hangs over burner.
make sure its in the correct position leaning into the flame.
otherwise call a registered gas oven repair man good luck
Nov 15, 2016 • Ovens
Whirlpool accubake
Almost all electric stoves vent the oven through a hole in either the back right or rear burner. They can get very hot. I am surprised that your control panel is burned. It is only dangerous if you place a combustible over the burner. I have had some people do this and it has melted it. i haven'y heard of a fire from this but it could happen if it was hot enough.
2answers
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
2helpful
My oven will not ignite, what's the problem?
Hello there:
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other causes Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective.
1helpful
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 • Ovens
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
1helpful
Oven won't light, even with ignitor getting red
Bake igniter
Other causes
Gas range top burners too hot
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
