You should have a remote control to power it ON. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
SOURCE: (TV) Remote Code for Panasonic TX 15LT2
For what is required, I will not pay $9. Obtained from a free site. Thank you anyway.
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
SOURCE: We lost remote control of samsung TVHD: TX-S3082LUH TV
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/us_electronics_uf4200c_manual.pdf here is the link to the 200B remote manual and the codes are on page 3
SOURCE: what code do I use to set up my sky hd remote to
With you sky remote follow the steps below:
TV
RED + SELECT ( flashes twice )
TV
0051
now try the volume button. If this works then press SELECT to save. If not press TV and then volume again. Repeat this step until the volume works then dont forget to press the SELECT button to store the code.
Job Done. Please leave a thumbs
Cheers
Little Dish Fitter
