Try it yet,
install w7?
with internet connected,?
let W7 install find the drivers as it loads. ,PnP. plug and Play.
do that yet?
keep in mine that is server , not PC or workstation
nor do I know what vga chip or card GPU is in your ML110.
It did not come with W7
see proof here.
https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c01928098
GLP embedded Matrox G200
Matrox shows ZERO
http://www.matrox.com/video/en/support/downloads/
8 year old server.
HERE IS what Microsoft has in there PNP server, (catalogs)
official
http://www.catalog.update.microsoft.com/Search.aspx?q=matrox%20%20G200
what you see is what you get.
why not add any w7 video card to the expansion slot.
spend $5 used. endless choices.
some g6 have x16 slot PCI express any card works there ALMOST ALL ATI LEGACY CARDS HAVE NO W7 SUPPORT,VISTA MAX ON MOST. OK?
what I do to learn what is the oldest and cheapest card from ATI that does W7, is I go to the official MS, PnP, servers. and look.
ever do plug and play?
seems you did and found out your GPU chip is from a dead chip maker. so
what can we uses, well best is Nvidia and ATI'/amd is next.
RaDEON HD ? 3410 UP? SPEND $6)?
to find cards that have good drivers you only need look here first, at MS, driver catalogs, pnp
900+ drivers for vast cards, for free, and 100% MS certified and by ATI, (amd/ati) has it too.
http://www.catalog.update.microsoft.com/Search.aspx?q=radeon%20hd%20windows%207
see that?
I hope this helps HP ProLiant ML110 G6 Drivers Download for Windows 10 8 1 7 Vista XP
nice malware, sport.
SOURCE: I INSTAL WINDOWS XP PROFESSIONAL
Because you are installing a desktop operating system onto server hardware there are logically no drivers available for the system hardware.
SOURCE: FROM WHERE CAN I DOWNLOAD
Hi ppswalia I hope this helps. If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Since this is a Server, rather than an ordinary Desktop computer, it is not designed to work with normal Windows XP Operating Systems. It is designed to work specifically with Windows, Unix and Linux Server Applications. See here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3577715&lang=en&cc=us&taskId=135&prodTypeId=15351&prodSeriesId=3577708
There are 2 things you can try.
You can try installing the LAN/Ethernet Drivers for the various Windows Server versions from the above official HP Downloads and Drivers Support Website and see if one of them just happens to coincidentally be compatible with XP SP2.
Assuming there are no further compatibility issues between other Server Motherboard Devices and Win XP SP2 Drivers, you could open the Server case and either bypass any on-board LAN/Ethernet/NIC Port or remove any separate LAN/Ethernet/Network Card installed and install, instead, a pre-confirmed Win XP compatible LAN/Ethernet/NIC Card and then install the drivers for the new card.
Thanks for using FixYa.
