SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
SOURCE: Panasonic KX-T7730 Diverting Calls back
If you set call forward all calls then lift your handset press the FWD/DND button, dial 0 , you should get a tone, then hang up. If you set Follow Me then dial 8 and your extension number instead of the 0 . Good Luck. ....Mike
SOURCE: lock extension with my Panasonic KX T7730
Do you need the default lock code because you already did this, or is it locked and you can't unlock it?
This is probably close, but in the American version it's 77 lock lock # to set and 77 lock # to release, where lock is a 4 digit number.
The System manager can release all locks from their phone. You'll have to make arrangements with an "engineer" to get those codes.
Carl (working on Br terms)
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
DON BOTHER ASKING ON HOW TO CHECK THE CALL HISTORY, TODAY I CALLED A CUSTOMER SERVICE SHOWROOM IN DUBAI, AND THEY SAID THAT THE PHONE DOESNT HAVE THAT FEATURE
