SOURCE: GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
SOURCE: My Whirlpool Duet front loader is ripping my
My washer ruined 2 king sheets 3 shirts and brand new jogging suit, so I know what you mean! The rubber gasket ...it had 2 metal bands..one on the inside which is a wide one and a small thin one on the outside of the gasket. You really can't see the wide one unless it has started to slipped off or break. or by taking the ting one off,..my wide band came loose which caused the screw to be exposed just enough for something to catch on it, tearing the material, it kept wrapping around and around untili eventually the band came completely off. I hope this helps.
Linda
SOURCE: Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
SOURCE: I am having a problem with my Ge dryer catching my
HHHMMMMMmmmm...seems like if it is an older dryer, the drum support rollers may be worn out. This can and will cause the drum to rub against the front of the dryer and snag the laundry inside.
To fix this, the dryer must be disconnected from the power source and the back panel removed. Before going any further, manually push and pull the drum to and from the front of the dryer and see if there's slack in the rollers. You'll probably need a helper for this.
If there's slack, remove the belt then the drum, and replace ALL the rollers at one time. There should only be 2 or 3 depending on the machine, they're not expensive nor are they difficult to replace once you're inside the machine this far. But do them ALL and you won't have to do this again more than likely.
After you reassemble everything and before you reconnect the power, see that the dryer is level. You can adjust this by turning the "feet" under the front of the dryer. This will prevent laundry from "migrating" to the front of the dryer and wearing out the rollers again.
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
