Question about Yes Televison & Video
Samsung led mu7350 curve messed with service menu now tv is not showing display. Is it possible to roll back with re-installing tv firmware? if yes how
    Top Expert:
  • Yes Master
  • 29,417 Answers
You will need a service centre to re-instal the settings from a pre programmed EEPROM.
Posted on Jul 31, 2018
Testimonial: "Thanks. Would give it a try ..."
4 Suggested Answers
SOURCE:
jahting
  • 70 Answers
SOURCE: When unit powers up - nothing shows - menu rolls
resit your projector to factory default. if problem occur clean the entire projector. or change your projection bulb.
Posted on Oct 08, 2009
SOURCE: Firmware Version
Phonr the nearest Bernina Artista Dealer. If the CPS 4.1 software should pick it up. I use CPS 4.1 data software on mine and it picks it up automatically.
Posted on May 26, 2008
  • 2075 Answers
SOURCE: Is it possible to change the firmware or platform on a polaroid smart tv 3-32-led-14 service menu..menu 4725 or jailbreak ???
Why do you need this? Have you referred to the Polaroid site?
Posted on Jun 11, 2015
Testimonial: "there platform crap wanna try and sticvk android on it instead so looking to flash it some how if poss do you think its possible there a option for usb"
Led tv showing horizontal red lines
Horizontal lines syptom is always related to its LED back-light section. Check and repair it first; if you can. Contact any service technician. In most cases, this fault might be of its display panel itself, because, most models of the Samsung TVs, the T'Con and LED drive system circuit are built in part of the display panel. If so; the repair will be almost impossible. Replacing the display panel will be the only remedy. As you know, it will be best to buy a new Tv; instead of replacing the Display Panel of any LCD TVs; as the cost of the panel + repair charge will come around 80% price of a new Tv. Check and confirm the fault is with its Display Panel. If yes; get rid of it. The decision is yours.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 02, 2015 | Samsung Televison & Video
Uncontrolled tv
Can you please check the CH+ CH- keys if any of them stuck.
Feb 18, 2008 | Televison & Video
Tip
How to find out the series number and model code of a Samsung Smart TV
1. From your Smart Remote press the Menu button
2. In the menu displayed in the TV , select the support option
3. Select Contact Samsung option in the Menu
This displays the Model number / code, firmware version and other details of the TV. Scroll down the popup menu to view other details of your TV.
on Jan 09, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Firmware for TFK 4208 LED
If you wish to get some details; visit the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Apr 29, 2017 | Televison & Video
HOW DO I UPDATE MY SAMSUNG LED TV FIRMWARE MODEL NUMBER UE46B8000XWXXU
Try opening your menu options and search for "updates" Usually when you set your TV for the first time it usually guides you to do this firmware update. Try acting like your are setting up your TV for the first time and maybe it will have a option for this.
Apr 01, 2015 | Samsung UN Televison & Video
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Samsung 7000 on screen menu
It seems that the firmware corrupted. Just do a hard reset to this TV, and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset. If this do not help you, a firmware update should be done with the latest firmware, than it has been installed now. Contact authorized service center to get the latest firmware to your model TV by USB. If you wish to get more details, check the link given.
Jun 01, 2013 | Televison & Video
Samsung HC-P4752W No Color
Do not automatically think you need to go into the service menu. I bet you 100 to 1 that you pulled out a plug or a connector somewhere OR one is not seated into the plug all the way. If the set worked with color before you messed with it, there is not a problem in the service menu. The service menu is not the fix all thing. it is there to make fine alignments and adjustments, and as a matter of fact, messing with a service menu even with the service manual is very dangerous. I have seen peeps ruin TV sets by messing around with the service menu alignments. STAY out of these alignments. they are not going to fix a problem that all of a suddenly comes up. Repair the problem in the circuit first. Good Luck
Sep 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
