SOURCE: Precor C846 Recumbent Bike - heart monitor not working
You can test the HR grips to see if the wiring is good all the way from the contact grips to the upper board by doing a test with your meter. Get a meter that can test fuses and beeps if the fuse is good.
disconnect the 4 pin brown connector at the console board, on one side will be some metal contacts.
Touch one end of the meter lead to one wire and the other to the HR contact plate on the handlebar. try all the contact plates on the handle bar until it beeps, then move the lead to the next wire and repeat until all contact plates beep. It all of them beep then your wiring is ok and the problem is in the Heart Rate board in the console or the connection point on the board.
Let me know how it turns out.
Santafe
SOURCE: where can i buy the optional heart rate board for
Call Precor @ 1-800-347-4404 they should sell you directly
SOURCE: How do I enable my EFX 544 to give my heart rate
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
SOURCE: I have lost the manual/directions for my Bowflex Heart Rt Monitor
The name of the manufacturer could help you, maybe those links will.
http://www.amazon.com/Fitness-Trainer-Strapless-Monitor-Pedometer/dp/B001UI7M9S
Bowflex heart rate monitors ]
Bowflex heart rate monitors pedometers step counters - Bowflex UK authorised heart rate
http://www.bodybuilding.com/store/bowflex/classicstraplesshrm.html
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
