Question about Patton Computers & Internet
All of a sudden, I am unable to connect to Wi-Fi. Jackie Patton
  • Patton Master
  • 26,408 Answers
Reboot router, reboot the device.
Posted on Jul 31, 2018
SOURCE:
  • 192 Answers
SOURCE: my d-link 2640t wireless router suddenly no Wi-Fi
This one can be one of two things.
If you have a digital multimeter, check the power connection and make sure that it's not to high (eg. 7.5 V DC should read no more than 7.8 V for it to work properly)
Otherwise, just reset the router. I have a feeling it is the first one.
Once it reaches to 130% above of what's rated, it can fry your network adapter in your computer and possibly more damage if it's wired.
Posted on Aug 09, 2009
  • 742 Answers
SOURCE: wi-fi connection problem
There are 2 ways to approach your problem.
  1. Un-protect your wifi connection by removing the password. This is risky since other wifi gadgets can readily connect to your network.
  2. Configure your Samsung phone to connect to your password-protected wifi. Make sure that the wifi protocol of your phone matches that of your wifi router. Example, make sure to set WPA or WPA2 on both device.
Posted on May 08, 2010
virtualhost
  • 2185 Answers
SOURCE: My Samsung Galaxy 3 -
To be able to find out the MAC address of your Samsung Galaxy phone, please do the steps below:
1. Press the Menu button, under the display on the left hand side.
2. A menu panel appears onscreen. Press Settings.
3. The phone's Settings menu appears. Press Wireless Controls.
4. From the Wi-Fi Controls Menu, press Wi-Fi Settings.
5. Press the Menu button (to the left under the display).
6. A menu pops up onscreen. Press Advanced.
7. The 12-character MAC address is listed in this menu.
There you go, you just have to add the MAC address where required in the appropriate place in the Wi-Fi router's configuration set up.
Please let me know if this helps you. Thank you for using FixYa.
Posted on Oct 13, 2010
SOURCE: Unable to Connect to WI-FI with my Samsung Galaxy
I just had this same problem - I suspect it may have been a new app I installed that changed some settings.
I fixed mine by going into Settings>Mobile Network settings, then tick "Use packet data". Worth a try.
Posted on Dec 25, 2010
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
Jul 18, 2014 | Samsung Galaxy Tab Tablet PC
Wi- fi
I would say you have a problem with the router unless you are not reading the situation correctly, the other alleged connections will not be accessible for any reason unless you are the one paying for that connection, it would be illegal otherwise, so i am going to assume that you have a faulty router.
Jun 22, 2014 | Acer C7 Chromebook
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
Unable to reconnect to wi-fi
If you have not done so already, reset the player to factory settings and try again. If an ethernet cable connection is available, use it to get the best connection speed.
Dec 12, 2013 | LG DIGITAL/AUDIO/VIDEO Lg Bp330 Blu-Ray...
How to connect wi fi for c2 03
how to setting wi-fi
Mar 28, 2012 | Nokia C203
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
I cannot make a wi-fi connection
are you that ******* stupid that you think that blackberrys have wifi you ignorant lowlife ***** you cheap ***** blackberrys do not have wi fi you better go to a low quality iphone with that **** you have been dismissed wiht your stale ***
Jun 17, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
37 people viewed this question
Top Patton Computers & Internet Experts
Alun Cox
k24674
Are you a Patton Computer and Internet Expert? Answer questions, earn points and help others
