Follow the link to amazon https://www.amazon.com/PhotoSmart-Digital-Camera-Memory-Standard/dp/B00PW85LUY
SOURCE: won't read sd card - says card not suppoorted
Did you try putting the card in the camera, and using the camera's "format" card option?(Make sure there is nothing on the the card-a format will delete it.) Often times, a digital camera requires a format of the card so the proper file/directory structure can be created. If the card is empty, you have nothing to lose.
SOURCE: camera won't work
HP technical Support is the 1st place to go - in case there is a repair/replacement solution. If the camera is over a year old - an economical repair is unlikely
SOURCE: I have taken my memorey
Go to your menu and settings for the card and format it. That way it will be fit for your camera again. (:
SOURCE: HP Photosmart 945 Digital... Problem
Remove the batteries and SD card for about 5 minutes. Reinsert and see if that resolves the issue..
SOURCE: My HP Photosmart R707 Camera not reading memory cards
If the memory card you are using is an SDHC designated card, your camera is probably not compatible with it. SDHC cards are usually 4gb and larger. Check the card for the SDHC label.
