Check out this website:
http://www.appliancepartspros.com/search.aspx?q=DWD-WD32WS
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Testimonial: "thanks so much for your help"
SOURCE: Daewoo wash machine air power 7kg Model DWD-F1013.
i bought used but good working daewoo f1013 washing machine in dubai,
i can not spin. no drying. i dont have user instruction manual.
please help
SOURCE: I have a Daewoo DWD FD1233. It's brand new &
Daewoo e8 - engine error! or Bad soldering.
Remove the control panel (the one in which many connections). Remove the rear rubber compound around contacts blue relay.
Resolder them. And it will be all ok!
Or - remove the entire back of the compound and look for where the bad soldering (cold soldering ). You can see it - blackened or exfoliated. Just solder all.
