If you have restored the TV to its manufacture factory setting and still have the same issues, and also have tried to adjust it manually, more likely your TV is going out soon and needs to repair by the certified electronic repair facility. Because of the brand/model, is really not worth fixing. By the time you invest fixing it, you can by a brand new TV from Walmart a Sharp, JVC and Toshiba 55' for under $300 bucks. In addition, there's no setting you can do or adjust to resolve your TV issues when it comes to LED colors malfunction. If this is a Dixon 55" TV, it an OK brands. Dixon, Sinotec, and Hisense are cheap TV, and I doubt you going to get a good service longevity out of those bands.
SOURCE: Restore factory settings.
Here is the Dell tech support article for PC Restore to re-image the system to the factory settings.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=5A9D1CCAB17AB24BE040AE0AB5E12BFE&docid=325300
SOURCE: AIM 54 cm TV locked
Not sure if this is the same TV as I have but keep the "music" button down until the screen comes back. Hope it helps.
SOURCE: I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
SOURCE: restoring my dell to factory settings
If you want to clear off all of your files and reset it to how it was when you first got it (Factory settings), hit CTRL + F12 when the computer is booting up.
See this link.
SOURCE: acer aspire password to restore to factory settings
well if its the boot password you have hope,ALT+F10 on start is supposed to get you to the recovery manager,if you cant get there restore factory default,if its the windows operating system password,you can try to type administrator in the user name and leave the password blank,sometimes your able to get in on the built in administrator acct.,if that doesnt work,,its not easy you can download password recovery programs and try that,if its the boot lock password you can take it apart and remove the bios battery on the mother board,remove main battery ,unplug power set something on the power button heavy enough to hold it down and wait,the longer the better,one day ,maybe two,reassemble and it should be back to factory default, if its under warranty send it to acer,nowif your able to get past the boot password and the windows password is still holding you up you can one-time boot to a windows disc and reinstall new copy,warning! you will loose everything on the computer,but at least you can use it agian hope this helps,aloha from maui todd0708
