Try to reset the thermal cutoff, but should be no reason why it should have tripped. The actual operating procedure is The air enters the body of the dryer through the large opening in front of the dryer Then the air is sucked past the heating element and into the tumbler. (the tumbler is the large bin holding your clothes). Then after the air has circulated around the clothes, it enters the door and is directed down through the lint screen. (this catches lint from the drying process... some clothes producte more lint (such as towels) than others (such as panties) because the weave is more coarse. Then the air passes through a duct in the front of the dryer (after the lint filter) and into the fan. The fan forces the air into the duct leading out the back of the dryer, at which point it exits your house. It is extremely difficult to tell you the problem without being there to eliminate any one of several things that could be the problem. First, when you have the dryer turned on and have the heat setting set to cottons, is there ANY heat at all? If you feel the door, and there is SOME heat but there is not much heat on the clothes when you feel them, the intake opening in front of the dryer is probably in need of cleaning.
While you should always clean your lint filter after each use of your dryer, you should also periodically clean the intake at least once every six months. If you do not, the air intake is eventually restricted and the drying efficiency of the drye is affected. Consult your owner's manual for the exact location of the air intake.
IF THE INTAKE IS CLEAN and clear of obstruction, and there is still not enough heat to dry the clothes, but the door feels warm when dryer is operating. Then this would imply that the exhaust duct needs cleaned out. This is something that definitely needs done periodically to prevent fire. The exhaust duct collects additional lint that the lint filter misses. While this is a small amount of lint, over a period of time, this builds up on the inside of the exhaust duct and prevents the flow of the exhaust which reduces the heated air flow around the clothes in the tumbler. This results in the air not flowing and not becoming warm enough to dry the clothes efficiently.
IF THERE IS NO HEAT AT ALL: Then there is a likelihood that the heater itself needs replacement. This is a costly repair and you will be wise to invest in another dryer instead.
The working process of your clothes dryer is a relatively simple machine. It brings in air, heats the air, flows the air through the tumber where the clothes tumble loosely with the heated air circulating around them, then the air passes through the lint filter as it exits out your home. The lint filter is necessary because those tiny pieces of fabric (lint) can collect in your exhaust duct and catch fire. This is the major cause of dryer fires. This is why you should also periodically clean out your exhaust duct. Even though you have a lint filter, the lint filter does NOT catch all the lint and lint will eventually coat the interior walls of the exhaust duct.
You should post model number and manufacturer for better answers, but all dryers have an exhaust duct that builds up lint in it over time. I take mine apart every few years and it always has lint built up in the exhaust before it even gets out to the vent pipe. Mine is a Kenmore/Roper, and to take the exhaust duct out you take out two screws from the top under the lint filter door, and then take off the back cover and remove four screws from the duct itself. Then I scrape it out and/or vacuum it with my shop vac. I'm heading away from the computer for the night, but if you post model information I'll take a look tomorrow evening, or one of the other experts here can help you out.
Best wishes, and thanks for using FixYa!
First check that the exhaust duct is clean, has no kinks and that the air flow is unrestricted. Sometimes water will condense inside the exhaust hose and not allow the damp air to flow.
I assume that the dryer works quietly, if not, then probably the blower fan needs replacing.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
disconect dryer from electric outlet first before doing anything to it!!
check ur outside exhaust vent on the house, might be full of lint, if is ok then check the duct on the back of your dryer, might be full or lint, take an leaf blower an blow all the lint off the air duct, an also if you are handy, remove the 12 or 14 screws of the back of the dryer , take the back panel off, and on your left side u will see the air port where the hot air comes off the dryer take the aditional 4 screws an clean it
then put it back together
if you still have the problem then u have bad coils
what happens an air restriction will cause the dryer not to work properly, it will overheat an shut off. but am more sure u need coils specially if u never got em replace, maintance doesn't hurt at all......
The thermal fuse only shuts off the elements if the proper air flow isn't acheived. If the clothes are hot but still damp after the drying cycle then you have a blockage in the dryer exhaust either at the hose at the back of the machine or in the lint filter area. Check both and clean and your problem should be solved.
Couple of things to check, the blower fan assembly that is close to the lint filter, might be clogged or the exhaust duct hose might be too long and has too many bents, that restricts the air flow. check also outside for restrictions
