I'll find the part. I just need to know the OEM specs
Way to go tom
posted to HP Compac forum on computers
I moved you and the OP out of computers
that is why noboby can understand you, and then answer wrong.
amazing no>
and yes don;t come back. that is always a good idea (sarc off)
what not ask Lakewood this, it is there fan, not ours,
we dont make fans at fixya, not yet. maybe next week?
there is no lack of hot air here, as is on all forums.
my guess the motor start capacitor is bad.
call lackwood and ask for that or schematic or BOM or parts list
see what they say,
many things now, are throw-away. with no support at all.
ok I google for you
and here the are, ask them, its there design.
http://www.lakewoodeng.com/Category.aspx?cid=1066
SOURCE: want to know capacitor specs.
The capaitors should be clearly marked on the original capacitors. You will find a voltage rating and an MFD rating printed on them. The rule is you can go 10% over but never under on the ratings.
SOURCE: I need a replacement motor, 60 HZ 2.7 amp, for a
GRAINGER.COM ... .GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
SOURCE: are replacement motors available for these fans?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
SOURCE: I have a lakewood floor fan model HV21 , the
use a pair of needle nose pliers, gently apply pressure to one side of the rounded part of the clip, then the other. if you did it too hard open back up with a small screwdriver. never do this while clip is on the cap.then push back on connector. should have two brown wires, both are wired directly to start windings.
