I just purchased the e35 from a person that used very little. I took it apart and transported it home in my truck. I had to put it on its side to transport it safely. I reassembled it and everything works. I programmed it for a work out as user 1 and the incline worked and all the read outs worked, except for the levels. After 15 minutes I could tell that the incline was going up, but the level stayed the same. I pushed the level up button on arms and the one on console and receive level err meassage. I tried restarting machine, I tried pushing the start, enter, stop button and it still will not change level. It will allow you to program higher level but it will not increase.
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
SOURCE: Yukon a/c blower doesn't work on low settings
I really think the Blower resistor is at fault.
It is located on the Passenger side, directly next to the blower motor.
It has a 7 or 8 wire connector from controller, and then the 2 wires coming out for the motor.
They are VERY common problem.
2 small screws holding it in.
easy fix.
Part SHOULD cost in the $40-$50 range Depending on which Auto parts store you go to, Auto Zone will have this part and can give you the step by step instruction to get the job done.
Hope this helps.
Good Luck
SOURCE: Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
SOURCE: VW transporter,1.9 TD 1998 ABL wont start
Your problem is located behind the ignition switch.Remove the covers of a steering column behind the steering wheel.There is 5 or 6 wires around on black or white plastic switch.Change it.ATT ! Before removing the steering wheel disconect the battery and wait for at list 10 min. to deactivate the SRS airbags.
