There is an electronic program guide. However, it's limited. To see the current program and upcoming programs for the current channel, press the EPG button on the original Ematic AT103B remote. (Universal remotes may or may not match the function.) To see the other channel's program list, use the left/right arrows to scroll through the lists for all of the available channels.
You may find a web site like Titan TV, http://www.titantv.com/ , more useful. The site has a guide to all channels at once by time for your area OTA channels.
I hope this helps.
Testimonial: "Thanks, Cindy. I appreciate the help. Hope you’re having a great day. Shirley"
Usually this means that you need a different antenna or to move your antenna. If you are using an indoor antenna, you may need an external antenna. Make sure that the antenna is pointing to the transmitters. If you have an amplifier on the antenna, it may be damaged and could be blocking some frequencies. In that case, you may need to replace the antenna or the amplifier. In some places, surrounding objects can block the signal; trees and buildings are the frequent problems.
Please use http://www.tvfool.com to check where the local stations transmitters are located and the recommended antenna to receive each station. ( http://www.antennaweb.org is a similar resource but usually is too conservative in the list of available stations.)
I hope this helps.
(In my case, I point a large external antenna towards the local stations farthest away. This lets me receive those stations and the ones from closer transmitters. If the antenna rotates, I lose some local stations but may gain access to stations that are outside my area. Then I have to climb up and turn the antenna. I tried an antenna rotor but it eventually burned out.)
I do not think that will work, but try it.
SOURCE: Universal remote codes for a ematic 103b converter box
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
SOURCE: Universal code for ematic 103b digital tv box
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Do you have the TV's video input source selected correctly
Testimonial: "The tv video input source is 300 ohm terminals which is connected thru a balun to the converter box.There is no way to select tv input sources"
