I can hear the fridge running and freezer is OK. I checked the frozen food and they are still frozen after 24 hrs. What could be the problem? Thx.
Might be door switch or blub inside the fridge or here is a video to check the switchs
https://www.youtube.com/watch?v=WTewh4hk1V0
that might be why the lcd is off to if the switch is bad
SOURCE: The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad. When doors are opened, the fan stops. No cooling. When it closes, fan starts. Bulb is just an indicator of no power to unit...probably burned out contact in switch.
SOURCE: LG GR-349R bottom mount freezer gets heavy ice
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
SOURCE: brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
SOURCE: LG express cool no frost
Just defrost the fridge. Once defrosted, the food compartment below the freezer should cool.
Hi Jamahl. Did you find the cause as mine is doing the same? Thanks David
