Question about Frigidaire Kitchen Ranges
Can you tell me how to remove the range main top assembly of frigidaire model fggf3047tfa ?
SOURCE:
robotek
  • 1512 Answers
SOURCE: I am looking to replace
Hi there
You can get the part from here
It is not very complicated job to replace it. You, probably, will need somebody to give you a hand.
To start, remove the screws from the front of the main top holding it to the frame and lift it up. All burners are attached to the main top. Remove them one at a time, remove the indicator lights (they have the locking clips) and then release the main top from the hinges (under the control panel) and remove it.
Assemble all parts in the reverse order.
I found this info here. There is quite a bit of info regarding this procedure if you wanted to have a read up to get your confidence up:)
regards
Robotek
Posted on May 06, 2008
SOURCE: bybass auto shutoff (frigidaire gas range ES340)
Look on page 10 of the use and care manual under "To Set Control for Continuous Bake or 12 Hour Energy Saving" Page 10 in my manual.
Posted on Sep 09, 2008
Maytag317
  • 1136 Answers
SOURCE: oven does not work, but the range top will?
Hi, Are both the bake and broil elements out?You will need to test the bake element first. Sometimes the element will have bubbles in it where it went bad. UNPLUG the range and remove the 2 screws holding the element in. With an OHM meter, check the element to see if it has continuity. If the test shows an open circuit, replace the element. If the test shows a closed circuit, there could be a bad wire connection, or a problem with the thermostat/clock assembly.
The clock assembly cost is around $100.00.
It might be a good idea to call a repaiarman out to be sure.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 09, 2009
SOURCE: Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Posted on Sep 26, 2009
Macmarkus
  • 2605 Answers
SOURCE: How do you change the
Hello, welcome to FixYa
Based on your post, "How do you change the main door switch"
Attached here is a great tutorial for accessing the assembly for testing and replacing.
http://www.repairclinic.com/PartDetail/Door-Switch-Assembly/131763202/1531974
Let me know if you need further assistance going forward or if anything is not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Jun 18, 2011
How to raise the glasstop Frigidaire range
Hello, John -
The information here may prove instructive:
https://homesteady.com/how-7979236-replace-glass-stove-top-frigidaire.html
You can also add the model number of your Frigidaire range by choosing "Comment" and providing the model number so that I or another Fixya.com answerer can provide you with the user manual for your model of glass top range.
Best wishes.
Mar 29, 2018 | Frigidaire Kitchen Ranges
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Nov 12, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
How do I remove a main top for frigidaire gas stove model FFGF3047LSE and replace with a new one?
Hey friend, thanks for your post!
I understand that you want instructions on how to remove the main cooktop on your Frigidaire range, FFGF3047LSE. Some of these parts require precision and patience when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Sep 20, 2014 | Cooktops
Top blades Will Not Spin
Hi - I will suggest verifying that there is enough water pressure coming into the unit. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Oct 07, 2012 | Frigidaire GLD2445RF Built-in Dishwasher
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Frigidaire PLES389DCC MODEL Electrolux Professional Series My glass cooktop is cracked, where is the cheapest site to find a replacement glass
318223626 - MAIN TOP
found it listed from 230.68 at prosupplyco.com
up to 281.85 at Repairclinic.com
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Frigidaire FEF366 Electric Kitchen Range
Ignitor on Frigidaire model PLCS389DCC is not working. How can I replace it.
There are a couple of ways you can resolve this issue, depending on what isn't working. As it's difficult to determine by the brief description of the problem you're having, I can't tell if the main spark (ignitor) module is the faulty component, or if you need to replace a specific ignitor/orrifice assembly for one or more burners.
If none of the top surface burners are lighting when you turn them on, it is most likely the spark module that needs to be replaced. If it's only one burner that is not lighting, then you'll need to replace that burner's ignitor/orrifice assembly.
To get at these components, all you need to do is lift up the top range surface to expose the burner assemblies and the spark module. Be sure to turn off the gas line and unplug the range from the electric outlet to prevent any shock hazard, etc. Removal and replacement can be done with simple hand tools and by simply unplugging the electrical plug on the spark module.
Here's a exploded line drawing showing the components, part numbers, and a price list as well. You can order the part(s) needed online as well.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PLCS389DCC&productCategoryId=0122008&brandId=1428&modelName=DUAL-FUEL-RANGE&diagramPageId=00002&componentDescription=BURNER&documentId=R0504191&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not work, but the range top will?
Vic
Jul 09, 2009 | Ovens
How to replace maintop (cooktop) frigidaire oven FGFG79GBA
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
Dec 16, 2008 | Frigidaire FGF316 Gas Kitchen Range
I am looking to replace the main glass top to a Frigidaire 30" Electrice Slide In Range - Model PLES389DCB. Before I make the purchase I want to be sure I can do this myself.
Hi there
regards
Robotek
May 06, 2008 | Kitchen Ranges
Kitchen Ranges Logo
55 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
