Assuming you are using the Yamaha power adaptor you need to try and fault trace.
Is there power from the adaptor? If you have any other products that use the same power adaptor or have access to a digital multimeter measure the voltage.
If this is correct move on .
When you plug the power to the DTX express, does the socket feel loose?
If so the socket solder joint have failed - a fairly common fault Replace the socket ( this will require soldering )
If you still have a problem then the fault lies within the command unit and will probably need further specialist testing.
SOURCE: Weak LCD Display on a Yamaha DTX Electronic Drum Kit
NOT a battery issue.
Note that many of these devices have a parameter one can set for "contrast" or "viewing angle". You might want to check your owners manual for this possibility.
I downloaded the DTX manual and there IS a contrast control on the back of the unit near the top left facing the back...
IT MAY require a screwdriver to adjust it.
