SOURCE: Panasonic SA-HT05 Reciever wont turn
i had the same problem check if any of your speakers are disconnected mine i was doing some work to it and i let the wire accidently touch a peice of metal and it would play for a bit then just stop playing music it is something to do with it heating and such
SOURCE: error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
SOURCE: TV Picture does not come on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
SOURCE: Is there a reset button?
DO you have 24 Volts at the out door unit from the thermostat?
If so trace these 2 wires down. Both Will eventually go the what we call the contactor. While tracing down these 2 small wires see all the items they go to. You could have a High pressure switch (usually has a manual reset button on it) a low pressure switch, a delay timer and maybe a few other items I cant think of at the moment.
Usually the High pressure switch is the only one that has a manual reset. Where the button is depends on who made the switch. If its a red plastic body type the button will be on 1 end. If its metallic and rectangular it button will be about 1/4 inch long and protruding down 1 side of the rectangular box. Both of these type switches have a copper tube or a screw on mounting that allows the switch to sence the pressure on the out door coil (or if a heat pump it will be on the line on the compressor that goes to the out door coil or to the reversing valve).
If this helps you please giver me an outstdnbding rating and if you need more info please post and I'll get back to you. Thanks for using fixya.
SOURCE: My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
