Televison & Video Logo
makhosazana vilakazi Posted on Jul 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV Hisense 40 inch its on standby i bought all one remote its not working?
Mark Cheong
Level 3:
Master:
  • Hisense Master 791 Answers
  • Posted on Jul 27, 2018
Mark Cheong
Hisense Master
Level 3:
Master:
Answers
791
Questions
0
Helped
476230
Points
2475
  • Laura Combs
    Laura Combs Jan 15, 2019
    I see your problem and honestly I had a Hisense Tv so did my mother we bought the same type the same day and to be honest you will keep having problems out of their tvs , cause mine and my mothers rather got our apps to where the tv wouldnt support it no more , they will overheat and tear your system, not too mention you cant fix anything and their customer support are useless i would advise you to sale yours and get a good name brand smart tv
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on May 05, 2008
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Anonymous
  • 1124 Answers
  • Posted on Oct 17, 2008
SOURCE: Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Anonymous
  • 6487 Answers
  • Posted on Oct 23, 2008
SOURCE: hisense tv
Try this code 142, inform us for any updates.....
Anonymous
  • 8619 Answers
  • Posted on Jan 06, 2009
SOURCE: NEED A CODE FOR A HISENSE TV
Hi! You can get the code from the link below-
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/chunghop/rm88e-manual.zip&area=other
Anonymous
  • 55 Answers
  • Posted on Mar 29, 2009
SOURCE: i bought a rca universal remote that the code rca supplied for my
do a code scan read the manual it will show you how to do this
2answers
Where would the fuse be located on my 55 inch hisense tv
Unplug the TV's power cord and hold the power button directly on the tv ,keep holding it for 20 secs or so then let the tv sit unplugged for a couple of minutes before you try it again.
Hi, could someone please help me? I want to use an Alexa plug to turn on my hisense en3g39. But when it turns on it just goes into standby mode and then I have to use the remote to turn it on. How can I...
The Hisense EN3G39 is the remote control for the 55N8700UW, 65N8700UWG, and other TVs. I have never seen an option for removing the standby mode from any TV without a change to the firmware. The TV will always return to the standby mode when power is returned. The type of firmware change that you want will not be available from the TV manufacturer.
The smart plug is great for reducing your power bill when you aren't watching TV. It won't avoid the turn on step.
I wish that I had better news for you.
(I wouldn't recommend trusting a third-party firmware if one exists or was created for your TV. That would void any warranty and could cause problems with the TV.)
2answers
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
I have a tv set make Hisense 32 inches . I bought a universal remote control RM-139ES but the 'set' key does not illuminate when I hold it. Please help me d
0281,0188,0183.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Trying to find out what type of sound bar that will work with my tv
any sound bar will work. i have a LG 50" with a Samsung sound bar with a optical audio wire going from my tv to the sound bar. it comes with a bluetooth sub woofer and it sounds great.
36helpful
5answers
Remote control code for a Comcast remote, Hisense LHDN32V tv, code in maual 10748 doesnt work.
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Good luck
http://remotes.com/store/codes_original.html
Need remote control code for hisense EN-21660A
Does anyone know where I can get a remote for a Hisense 22" TV? I've bought a universal remote but after reading other people's experiences with the Hisense remote, I'm reluctant to even try it.
Top Hisense Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
MrFixitSTTL
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
