Learn How To Connect HP Wireless Printer to Computer, Laptop, Mac, and iOS Devices
If you have an HP Wireless Printer, you can either use the wireless connection method to print your documents wirelessly. However, if you don't have access to any wireless-enabled device, you can use the USB cable to print using the wired connection process. Once you know how to connect HP Wireless Printer, you can use devices like computer, laptop, iOS, or any other smart device to print all your documents using the wired or wireless printing methods.
Related Blog's
1.How to Make Generic ink Cartridges Work on a HP Printer?
2.HP Printer Not Printing How to fix?
3.How Can I HP Printer Driver Download?
4.Methods to Fix Hp Printer Not Working
HP Printer Blue Screen Errors
Https://www.printeralign.com/how-to-fix-wireless-printer-problems
Here you will get detail information that how can you resolve or fix wireless printer problems within very short period of time.
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later.
STEP 1 : BEFORE INSTALLATION
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
How to solve HP Printer issues 5X Faster Answer is inside
SOURCE: needing a hp c7250 wireless network code
You did not mention if you want to setup your laptop/printer connection directly (ad-hoc) or via a router.
Those are two very different procedures, so take a look at the manual (you find it here) from page 36 on ("Connect to a network").
I could just repeat everything, but the explanation is really good.
If you have further questions, come back here and let me know.
I'd be happy to help.
SOURCE: Cannot connect to wireless printer, pc is connected to 54g direct
You will have to either add the printer through the Add printer Wizard and do a search for a newtork printer
Your best bet would be to install the Software that came with your HP printer on your laptop...at some point you should be given options to find and connect to a network printer.
Don;t forget to Rate/Vote
SOURCE: my hp envy 15 laptop
dear friend,
visit this link to get your problem solved
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01891123&lang=en&cc=us&taskId=135&contentType=SupportFAQ&prodSeriesId=3995936&prodTypeId=321957
enjoy & cheers
SOURCE: Dell Latitude E6410 does not connect to wireless printer
connect it by cable to your pc first to install it then remove the cable
If you use windows operating system, you must install HP ePrint Software. For Mac, you can use AirPrint Soft. For using HP Envy 5660 wireless, you must download it from our website. for support call our Toll-Free 1-866-293-920
