SOURCE: Coffee does not brew
the heater eleiment is bad or the thermal fuses conncting the elements are blown
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
SOURCE: Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
SOURCE: Bunn cwtf15 coffee isn't hot enough
Adjust the thermostat, located behind the front panel, there will be a knob, turn all the way on then back about 1/4 turn.
SOURCE: I have a Bunn coffee
The manual for this coffee maker can be found at this link:
http://manualheaven.com/assets/bunn-nhbx-b-contemporary-coffee-maker-manual.pdf
While the manual does not contain repair instructions, it does have some troubleshooting tips to follow if your coffee is not staying hot.
