SOURCE: Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
SOURCE: I NEED A DIAGRAM OF A BRIGGS AND STRATTON TROY
Go to link below for a parts break down for your tiller. Starts on page 23
http://dl.owneriq.net/c/c23c1d7c-74ff-4347-b31e-a0ee0462b35e.pdf
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
