Computers & Internet Logo
Pamela Johnson Posted on Jul 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Apparently my battery is no longer working. Where can I get a new battery? And is this something I can repair myself just by opening up the back and replacing it?
Inspiron 15-7569 error code: 2000-0133
T Wolgamuth
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 280 Answers
  • Posted on Jul 25, 2018
T Wolgamuth
Master
Level 3:
Dedicated:
Answers
280
Questions
0
Helped
151327
Points
2183
5 Related Answers
Anonymous
  • 197 Answers
  • Posted on May 28, 2009
SOURCE: dell inspiron 6000 not charging
suspected faulty battery. replace the battery.
Anonymous
  • 5 Answers
  • Posted on Oct 14, 2009
SOURCE: need to replace the main battery in my Garmin iQue M3
procuring the battery is one of the problems you will have. The other problem is loosing springs on the toggle switches if you are not careful in dissasembling the thing.
Anonymous
  • 1033 Answers
  • Posted on Jun 28, 2010
SOURCE: On my 1997 Oldsmobile "eighty eight" 3800 engine
You can replace it easily, $74.99 2yr replacement. Just unhook the battery. the egr is a plug in play. once you hook it up, that's all needs to be done.
Anonymous
  • 3911 Answers
  • Posted on Oct 30, 2010
SOURCE: Driver side window no longer
No you buy a new regulator, that way the motor and the gearing is new. ebay or a parts store is far cheaper than a dealer. If you have skills and special tools for removing interior panels without damaging them, a collection of all the fancy glass fasteners at hand, and a couple hours set aside for scraping the skin off your knuckles then go ahead. otherwise take it to a glass shop and pay them 50 bucks to put it in for you.
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Nov 04, 2010
SOURCE: Shaver no longer holds a charge for longer than 1
You can repair yourself if you are able to solder the new battery pack into place. You will find the correct batteries at shaveroutlet.com. See link below (you will need two batteries)
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If you are unable to do this yourself, shaveroutlet.com can do it for you. See link below for information
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Testimonial: "Thank you"
My 42" Sanyo LCD TV which is 4 years old no longer
This is not a user repairable fault. Should be checked from its main power regulator board, and is a skilled work. Actually this is a repairable fault, but can do only by any technicain.
Remote sensor
try new battery and while the remote is open clean the contacts on the button side of the remote and the back of the buttons inside
Everex stepnote nc1510 wont reconize new battery
Were they genuine Everex OEM batteries, some cheaper replacement batteries don't always work.
I just had a look for Everex but apparently they no longer exist so genuine batteries are probably no longer available now..
http://www.engadget.com/2009/07/15/everex-us-is-now-closed
Then I found this but it's not much help.
http://www.everexcomputers.com/index.html
Then this, in case you ever need drivers: Drivers
Drive/worm gear on liftmaster garage door opener is worn out and no longer driving the chain to open the door. Apparently this gear is a common part and looking for detailed steps on how to replace it...
You did not specify the model of your door opener: However if you got the LiftMaster website you should be able to locate an Owner's Manual for your door opener.
Go here, select your model or series and then on the next page at the bottom right should be a link to the Owner's Manual.
The manual includes schematics, including the assembly of the motor unit.
You might find these illustrated instructions on similar product to be of use.
3helpful
Shaver no longer holds a charge for longer than 1 minute - can I replace the battery myself or do I need to find a repair agent?
2helpful
Garmin Streetpilot battery no longer works
just bought a battery for my Garmin 330 C off ebay for around 20 and put it in myself, not a bit undertaking although you need a battery operated soldering device to make it easy.
2answers
Nikon FG suddenly stopped working--not battery problem--help!
you should invest in a digital camera they have nice cameras for like 40 dollars on overstock.com
Mar 18, 2008 • Cameras
Green colour showing through photos??
Okay I called Olympus and they told me to try to reset the camera. I know you have tried using the reset option already from the meun, but apparently if you open the battery door, leave it open and hold down the Menu button and the okay button at the same time, it will (as the olympus guy called it) do a hard reset. This should restore the screen back to what he refered to as the factory settings. After you do that shut the battery door, and turn the camera off. Then turn it back on and you should be in business. it didn't work for me, but that is because mine was apparently sold to be after it was the floor model ( I had no clue). I have since returned it for a full refund. I thought I would pass on that the olympus help support people said.
2answers
NO POWER, CANNOT OPEN CASE
Bad Power jack on the motherboard and possiably a hairline crack on the board. I can help you please respond here.
4answers
Lens stuck help anyone
if you feel that the camera is making effort to extend the lense out and the lense is still jammed, get the help of a repairer.
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
