SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
SOURCE: Rheem Pronto RTG-74 error code C4
Error code 13 is "oxygen depletion sensor" activated.
The first number is a sequence indicator.
If you need the training manual I have it and can send it to you.
I got Rheem to send it to me a while back and it is a big help when working with these units.
It covers th RTG-42, 53, 66 and 74.
SOURCE: English Instruction Manual for a Toyo TA-09CHS Split Air Con Unit
I bought two TOYO split air conditioner in 2009. They are awesome, the best quality split air conditioner in Japan. I have two manual in English and I can mail you one. Please let me know how to mail it to you.
SOURCE: Ductless Air Heat remote
The solution is to remove Jumper J5 at the top of the circuit board. For that you will need to open the remote by removing the 3 screws underneath, split open the case and then remove the 4 srews inside. Removing such a small jumper requires precision and you should use a magnifier to focus. You can scratch it off gently using a flat blade screedriver. Test before reassembling. I have succesfully converted both of my remote to Celsius. Fujitsu is guilty for that, the metric system is around for over 40 years everywhere.
SOURCE: hi, i bought a toyota axio 2007 without an owners ...
Want to get a copy of the toyota axio (x) 2007 model.
