Question about Necchi Sewing Machines
I have a necchi sewing machine and having trouble with stitches sewing regular stitches then I get a long one
  • Necchi Master
  • 12,730 Answers
It is skipping stitches.
Use a brand new needle that is a suitable type for the fabric and thread you are sewing. If sewing knit, use a ball-point needle. If sewing woven fabrics, use a sharp needle (ie universal,
Use good quality sewing thread--no old or bargain bin variety.
Be sure to install the needle facing the correct direction. On most machines, the flat side of the needle faces the back of the machine, however, if the bobbin loads on the left side (not from the front), the flat side should face the throat of the machine.
There could also be a burr somewhere that is catching the thread and causing the skipped stitch.
What to Do If Your Sewing Machine Is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
https://fashion-incubator.com/10_reasons_for_skipped_stitches
All About Needles SCHMETZ Needles
Posted on Jul 29, 2018
SOURCE:
SOURCE: Necchi 4575
I've found that my machine doesn't like Coats & Clark thread; I have to feed it Guterman
Posted on Aug 04, 2008
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
  • 16 Answers
SOURCE: How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Posted on Aug 02, 2009
  • 12 Answers
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
Posted on Aug 20, 2009
RichSew
  • 220 Answers
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
Posted on Aug 07, 2010
How to sew Lycra on my necchi 522? I'm using a stretch needle. It goes up and down, fabric advances, but does not pick up bobbin thread - so no stitches!
Knit fabric sometimes plays a little havoc with machines. Be sure you are using a brand new needle. Also, ballpoint/jersey needles will usually work better with knit fabrics like t-shirt fabric. For very stretchy fabric like Lycra, you might want to try a Stretch Needle.
Schmetz Needles Needle Guide
Sewing Spandex Tips
If it still will not stitch, check your machine on regular woven fabric with a universal needle. Could be your machine is slightly out of time, especially if you have recently sewn over & hit a pin.
Oct 26, 2016 | Necchi Sewing Machines
How do I set the blanket stitch on my machine?
If you have the owner's manual, it should show the blanket stitch among the stitch selections for your machine. FWIW, a lot of vintage machines do not have a blanket stitch available, so don't be disappointed if your machine does not have it.
http://www.epinions.com/review/hmgd-Sewing_Machines-Necchi-Sewing_Machines-Necchi_Maxima_4575_Free_arm/22167788/43221487236
Mar 30, 2016 | Necchi 4575 Mechanical Sewing Machine
What is the difference in Necchi BF and Necchi BU?
Necchi BF is a straight stitch machine
Necchi BU is zig zag machine
Necchi BU Supernova had cams for additional stitches
Jul 17, 2014 | Necchi Sewing Machines
I have a Necchi 537L it was sold as a comercial machine that could do leather. Mine wont do soft paper! Whats up?
This is not a commercial machine and will give you trouble trying to sew upholstery,especially if you use heavy upholstery thread. You will get loops on the bottom.
It will sew only short stitches,No matter how long the stitch length is, because it only feeds the fabric from the bottom and it will stick.
It should sew regular fabric with normal threads with no problems. There is a pressure adjustment on the top of this machine which may be where your problem is located.Look in your book for instructions.Also, make sure the feed dogs are in the highest position. I don't know how long you've had the machine but if it has been awhile,remove the needle plate and clean the lint out from between the feed dog teeth.
sewman7
May 01, 2009 | Necchi 3537 Mechanical Sewing Machine
I have a necchi 4595, and well I cannot figure out the straight stitch....the dial doesn't show one?
It's just in the front panel, where the drawing of all the built in stitches are, it's the drawing number eleven from the left, you'll see a zig zag (red) and a straight stitch (black) Select A group of stitches (knob with the arrow) and then select the eleventh stitch (same knob but use the dial, look the manual) and then select zero on your stitch width dial. Hope that helps :)
Apr 23, 2009 | Necchi 4595 Mechanical Sewing Machine
Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Oct 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
60 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
