Power indicator shows a weak green light but no picture and no sound. I opened the back but found no bulged out or deformed capacitors. Not a heat problem because it does not turn on even when the tv is cold. When it happens, it usually needs to be unplugged for 8 hours at least to turn back on. Please help...
That problem is usually cause of bad capacitors on the power supply section..
As you stated your TV works fine and after a minute the red light comes on...
That
symptoms is cause of bad capacitors..Normally bad capacitors can check
visually if the capacitors look like leak/bulged on the top that is the
indication of bad one but not all bad capacitors are bulged some are not
so in that case you have to used a special meter called capacitance
meter..
hi sir good day
the green light indicator flashing which indicates error detected by processor. now here is my solution on how will you fix the problem. if you are going to do it with your make sure you have proper tools and at least a basic knowledge in repairing. now unplugged the unit then open the back cover to gain access the internal part of the tv. now disconnect the connector wire going to inverter board for back light then turn the tv, if the indicator stays green doesn't blink then all the voltage out put from the power supply is normal the 5v stand by,5v switch, 12v and 24v are present, you have bad inverter board or the back light itself. another way is if you disconnect the connector wire going to inverter ballast board then still light indicator flashing and no PS_ON voltage coming from the main board which switch the power supply to turn on i may say you have bad processor board. make sure no bulging capacitors at the power supply replaced it with the same value a panasonic brand FM or FC series much better with low ESR 105c rating. you can find replacement parts at www.digikey.com . hope this will help you feel free to ask further question good luck.
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
All you need is to open the back cover of the television and check on for dry soldering at the power stage of the printed circuit board, also check for bulged capacitors, if found replace with same rating of voltages , but if otherwise Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Solutions?
Solutions?
