Lands Phones Logo
R
Roy Palk Posted on Jul 24, 2018
How to Set time on GE 4837b - GE Lands Phones
1 Related Answer
Anonymous
  • Posted on Jan 10, 2009
SOURCE: GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
Why doesn't alarm sound when set?
Either the electronics are fubar or the noise making device is no good. Gotta checkout which is ng.
Need information on how to set time & date on a GE
Press and hold the STOP/SET button for two seconds, then release to access the set-up menu. The time/date setting follows the language.
The full details are in the "Changing the Settings" section of the manual (page 10 in my copy). If you need a copy of the manual, you can download one at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
19helpful
I have model #7-4837B AM/FM radio alarm clock. User manual has been misplaced and I am unable to disable the alarm.
On the top of the alarm clock is a CANCEL button. Press the button and the light next to the WAKE MODE indicator on the front of the clock will begin to flash. Press the WAKE MODE button on the top of the clock. The WAKE MODE indicator will go out and the alarm is off. If you want the alarm back on just press the WAKE MODE button again.
GE doesn't make this kind of product any longer but
on their site they say to call 1-800-447-1700 for assistance. Maybe someone there can find a copy of the instructions for you.
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
7helpful
How to set time on my ge phone 27958GE1-A
just before you press the button to set time, press "0"
How long do I set my ge oven to clean or is there a time set??
Normally the cleaning cycle is preprogramed by the factory, some models have a time setting which you can set, but for most, its preprogramed, there is no adjustment to the time, it will lock, run, and unlock to its programing, hope that helped.
1helpful
7-4837B clock radio
Press the Cancel button. While the wake mode LED is blinking (either alarm or radio) press the Wake Mode button. The wake mode LED should now be off. To turn off the Nap function before the alarm sounds, press and hold the Nap button for 3-5 seconds. The Nap LED should stop blinking and be off.
106helpful
4answers
GE Model 7-4837B
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
