SOURCE: Bright Star Br100P-D remote TV Panasonic
the remote is a hotel remote. Bright Star BR100P-D For a thomson tv. I just need to know how to reprogram the remote.
SOURCE: Remote Code for Orion to Time Warner Remote
Hey,
I've got 3 codes actually...
Try them won't you
0179, 0236, 0463
Hope this helps.
Thanks
SOURCE: remote code orion tv/vcr # tvcr0950bw
I had a bugger of a time trying to solve this exact same problem. I went through 3 universal remotes before I found a winner. Using the Jensen Surf Series SC-340 I managed to figure out the code for the vcr to be 687. This is not listed in the manual that I looked up for the remote, probably because the remote was made in 1997 while the tv/vcr is 1998. After trying the ~30 codes in the manual I set the remote to auto scan for the code. After 30min scanning for the tv code I switched over to scan for the vcr code. Three minutes later I get the code and that "Oh yeah. Who got this bad boy to work? You did! That's right!" kinda feeling. I hope this helps.
TLDR: I got a Jensen Surf Series SC-340 Universal Remote to work with the tvcr0950bw using the code 687 on the vcr.
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
