Refrigerators Logo
J
James Melton Posted on Jul 24, 2018
Where is the air vent/drain hole on the freezer of Samsung ModelRFG298HD (Refrigerator/Freezer with two top doors)
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 15, 2008
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Jan 11, 2009
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
David Stapp
  • 10 Answers
  • Posted on Feb 16, 2009
SOURCE: Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
I had a similar problem where the refrigerator side was not cooling well but I could feel very little air coming through the vent in the top left corner.I blew hot air from a blow driver into the vent for about 1 minute which melted ice that was hanging from the bottom of the vent cover.Cold air started blowing harder thru the vent and cured the problem.
shaun greyvensteyn
  • 159 Answers
  • Posted on May 16, 2009
SOURCE: Freezer works, refigerator get no cold air out top vent.
low gas level in the system
Anonymous
  • 232 Answers
  • Posted on Jul 01, 2009
SOURCE: Refrigerator warm, freezer is fine.
this could also be a plugged defrost drain ice building up blocking air flow through the return vents is therehwater dripping into frige
2answers
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
1helpful
Water leak under freezer door
the drain should be at the very bottom of the freezer. but it sounds like ur door gasket aint sealing all the way so ur freezer is trying to over compensate for the warmer air coming in
Water flowing into refrigerator. Ice build up behind freezer back wall. Will clearing ice from drains suffice or do I need a new heater? Foam drains to fridge are open. There is a small hole under...
hello again,
part 2 of the answer,the metal pan is the drain in the center of it is where the drain is blocked,the foam vents are the vents where the air from the freezer flows into the fresh food compartment,GENTLYclear that small hole so as not to puncture the tubing in the coil above it,or you will loose all the refrigerant(freon) an dthe ref, will be dead
Gene
4helpful
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
5helpful
Freezer is cold, but fridge isn't cooling, cleaned the coils underneath and the port between the freezer and fridge is clear of ice
All of the cooling in refrigerators is normally done in the freezer compartment. A fan circulates cold air from the freezer into the refrigerator compartment to cool it. Most likely this fan has quit working.
Also note that,
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. mostly, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since the unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.Hope this helpout , Good luck
Freezer & fridge not cold enough, frost in freezer
Refrigerator or freezer is not cold enough
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Water coming from freezer vent into refrigerator
the drain hole in the freezer is clog ,
open the freezer back wall and make sure the drain hole in the middle bottom under the coils is free al the way to the pan next to the compressor. you clean it with hot water and a pump, use hair dryer first if it is frozen on the top. good luck let me know if you need more help.
2answers
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
1helpful
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
10helpful
2answers
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
