It's a android tv, 2018 model. Looking for key sequence or buttons to enter recovery or hard/factory reset. Tried power button long press. Long hold before and after power and so on. Nothing works.
I searched, and the manual for this model is useless for this problem (the "factory reset" option is in one of the inside menus, which you won't be able to see.
I can't promise this will work, but in most Android devices that I've worked with, there is a two-button combo. With the device turned off, simultaneously press and hold the "volume-up" and the "On" buttons, which would turn it on and boot in basic mode, which in turns allows a hard factory reset in the options.
Best of luck,
Charlie.
SOURCE: DMR-ES30V remote and DVD panel buttons not responding
I assume you have fixed this by now, but if not, call panasonic's help line (number is in your owner's manual). They will walk you through the complete reset process (maybe 5 minutes). you will have to re-program everything the same as you did when it first came out of the box, but that doesn't take too long. Also, first try taking the batteries out of the remote. Make sure they are still good. Wait 60 seconds or longer, then replace batteries.
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
SOURCE: mitsubishi ws65869 big screen tv
We have a Mitsubishi big screen Model WS65869, moved it to the another area of the living room Transfered cables, and now all it will do is flash its green light and wont stop. Normally in the past it has not done this, so what could be the problem??
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
SOURCE: LG Model LHT754 stuck in demo mode
hold the stop button on the receiver not the remote! for twenty seconds
