Just changed the batteries and just bought the boat from a privet seller, so know nothing about the boat, and the manual doesn't tell me anything about an alarm
SOURCE: new battery, can't reset alarm
remove the alarm,their might be a passive switch on the alarm to turn it off with a special key,if you dont have the key break the lock so you can turn it off or try to open case of alarm and look at wires and then dertimine which ones to join or break,every alarm inside is different so you will have to work it out.
SOURCE: alarm system on hyundai xg350
disconnect the the alarm speaker by taking one end of the speaker inside engine compartment, it looks like horn, follow wires and look for one of both (any) and cut it or disconnect if You find terminals, Your Relay is the problem, or your switch
SOURCE: alarm keep going off
Try putting the door key in the passenger door and turn it to the right. This should disable the factory alarm.
Hope it helps man, drove me crazy with my '86 Vette.
SOURCE: 2004 Eclipse won't start. When key is turned
sounds like you have an ignition problem, check the ignition fuse under the hood sounds like the fuse is blown, if that dosent work check your starter solinoid
I’m happy to assist further over the phone at https://www.6ya.com/expert/john_2c7bb9c157d0baa8
SOURCE: 1999 jeep grand cherokee lareado key alarm won't
i have this same problem
however,i only have a key to enter my cherokee
this solution sounds like it is for a remote
any ideas on how this can be solved
