Washing Machines Logo
S
Suleman Posted on Jul 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does whillpool washing machine shake when spinning
T Wolgamuth
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 280 Answers
  • Posted on Jul 23, 2018
T Wolgamuth
Master
Level 3:
Dedicated:
Answers
280
Questions
0
Helped
151132
Points
2183
5 Related Answers
Anonymous
  • 360 Answers
  • Posted on Feb 16, 2009
SOURCE: Washing Machine Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this a fix ya rating
clarkco
Anonymous
  • 109 Answers
  • Posted on Mar 29, 2009
SOURCE: shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
pumpkinman
Steve Sweetleaf
  • 1212 Answers
  • Posted on Jul 01, 2009
SOURCE: shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Anonymous
  • 92 Answers
  • Posted on Jul 15, 2009
SOURCE: Shaing during Spin Cycle
sounds like the bearings have worn out,to check for this open door and lift inner drum up and down if you feel like a knocking sound then this will be the bearings have worn.
Anonymous
  • Posted on Dec 08, 2009
SOURCE: Crosley CW6000 Washing Machine. When my washing
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Why does whillpool washing machine not want to spin
Is it a top loader? If so, the drum may be out of balance re-arrange the load so that it is about even all the way around and try again. or ..
Troubleshooting Washing Machine That Won Spin DoItYourself com
Why Won the Whirlpool Washer Spin or Drain
Whirlpool washing machine imperial series My washing machine is shaking hard when it spin dry
Well if it's a new machine then it look normal or let me know if you note some changes in natural function, most of this series washing machines shakes hard when they are on dry spinning. This series is mostly known for dryer's.
Regards
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
1helpful
Shaking in spin cycle and tub moves too easily in washing machine
Shakes during spin cycle
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Top Washing Machines Experts
john h
