After getting gas my car began stalling, Advance error said AIr intake sensor..checked that cleaned an replaced doing same thing can't find fuel filter to replace
Where is the fuel filter for Nissan Xterra 2003 located on the car
use google to find all information 2004 Xterra fuel filter location
there may be other problems, change filter, if that does not work quit throwing money and parts at it may be cheaper to have it repaired.
SOURCE: car runs rough at idle
clean out ur throttle body, just follow the hose from the air filter to the throttle body. Need 2 people to do this. Don't remove the hose completely from the throttle body. Just enuff to be able to spray ur intake cleaner into the throttle body. Do this especially if its worse when the motor is hot, as this would confirm the problem.
SOURCE: P0171 Code (Lean Fuel Bank 1) Engine light on
PO 171 indicates a lean condition in bank 1 or the same side of the engine as the first cylinder , usually it is caused by a vacuum leak some where check to make sure that even the smallest of vacuum hoses are in good condition and not leaking
SOURCE: Stalling around 15 30 mph
I would try insoluating the fuel lines anywhere they go past hot parts.I would also run some fuel cleaner in with a few tanks of gasoline. It has done wonders on my truck of 189k. Lean or no fuel related problem do not set codes. Too much unburned fuel sets codes.
SOURCE: check engine light 2000 chrysler cirrus
if you live in the states autozone will scan the codes for free
SOURCE: 1989 GMC 2500 5.7L - engine surges and stalls at idle. Loses power at cruising speed.
Wow you have replaced a lot of stuff. Lets go back to the Fuel pump. When you replaced it did you replace the hose between the pump and the sending unit. These are common for splitting. Have you hooked up a fuel pressure gauge to check what pressure you have? It should be real close to 13 psi and should raise to at least 18 or 19 when you pinch off the return line.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Here is the common cause of surges, cold stalls, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours.
To correct this problem get a can of throttle valve cleaner (it is made by CRC) from the local auto parts store, spray it into the air intake of the engine until you have used about half the can, you will need to hold the idle up while you do this, it will try to stall, after this shut the engine down and disconnect the Negative (-) battery cable for 5 minutes. The intake is know clean, if you continue to have the stall out the idle speed control valve may be defective and requires replacement.
Hi. The fuel filter is located underneath the truck. It sits hidden on top of a crossmember, behind a steel plate. It is near the exhaust and the end of the fuel tank. Good Luck.
