SOURCE: windows vista admin password
I don't think the Guest account has sufficient rights but you can try this:
Go to Start -> Run -> type: cmd and press Enter/Return.
When the CMD prompt shows up, type the following:
net user Administrator ""
this is what you just did: net user Administrator lets you change properties for the user Administrator. The double " changes the password to nothing. You can also type:
net user Administrator <whatever word you like>
Offcourse without the brackets. Mind the spaces between the commands: net<space>user<space>username<space>new password.
If this doesn't work look for Winternals ERD Commander on the Internet. This creates or is a disc with tools. Put it in your drive, reboot (from the disc) and choose the installation you want to manage. Then look up the tool for changing the Administrator password.
Let me know if this was helpful, please rate.
Greetings,
DarkNeogen.
SOURCE: Lost Admin password for SSL-VPN 2000
This is as close as I can come.
http://www.sonicwall.com/downloads/SSL-VPN_2000-4000_2.1_Release_Notes.pdf
SOURCE: Admin account on Vista pc locked out, forgot admin password
Step 1
START THE COMPUTER. DO THIS BY PRESSING THE POWER BUTTON. DO NOT WAIT UNTIL WINDOW LOADS TO PERFORM STEP 2.
Step 2
PRESS F8 KEY ***BEFORE*** WINDOWS VISTA BEGINS START UP. THIS WILL PROVIDE A LIST OF OPTIONS FOR HOW TO PROCEED.
Step 3
CHOOSE TO START YOUR COMPUTER IN "SAFE MODE".
Step 4
OPEN THE START MENU.
Step 5
OPEN THE CONTROL PANEL (from within the Start Menu).
Step 6
SELECT "USER ACCOUNTS AND FAMILY SAFETY" IN THE CONTROL PANEL POP-UP WINDOW.
Step 7
CLICK THE "CHANGE YOUR WINDOWS PASSWORD" LINK BENEATH THE "USER ACCOUNTS" SECTION.
Step 8
CLICK "REMOVE PASSWORD". VERIFY AND SUBMIT.
Step 9
RESTART YOUR COMPUTER NORMALLY. DO NOT PRESS F8.
Step 10
TO RESET A PASSWORD, ACCESS THE "USER ACCOUNTS AND FAMILY SAFETY" MENU AGAIN. THIS TIME CLICK "CHANGE YOUR WINDOWS PASSWORD", PROVIDE THE DESIRED PASSWORD, VERIFY AND SUBMIT. THIS TIME, WRITE YOUR PASSWORD DOWN.
If this helps please rate me. thanks
SOURCE: ACER 5630-6288 Win Vista Home Premium Admin Password forgotten
yes there is
login with ur normal user profile
go to run>>type cmd
in the black box...
type net user administrator
it will give u options to change the pwd for administrtaor
SOURCE: hi , i have forgotten
In that case you will have to reset it offline, using this
http://pogostick.net/~pnh/ntpasswd/
