Cameras Logo
m
martha monaco Posted on Jul 21, 2018
How to turn flash on my iex29 polaroid camera
1helpful
Where does the SD Card go in the iEX29 Camera?
Is this not covered in the camera manual ? I am nor familiar with this particular model, but the SD card slot is often located in the battery compartment in consumer digital cameras - have you tried that ?
Mar 21, 2017 • Cameras
I need a manual for iEX29 Polaroid camera
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Polaroid digicam no flash
If the camera is working normal and the flash is not turned off then the camera will need repairs, the flash unit is not a user fix item.
The Flash is stuck to off on my Polaroid x800 camera. How do i fix this?
If Polaroid x800 flash doesn't turn ON - that is because of the picture mode (a plastic switch on one of the sides). In my case: mountains symbol - flash turns ON/OFF, flower symbol - flash is stuck to OFF.
May 23, 2012 • Cameras
1helpful
With what can i cover a polaroid flash
The Polaroid 600 doesn't have an automatic flash. To use the flash, insert the flash bar into the flash socket. To turn off the flash, remove the flash bar. Refer to the manual.
If you have a different camera, please reply to this post and give the model number.
Can you turn off the flash on the Polaroid i1237?
Press cursor-right repeatedly to cycle through the different flash modes. To turn the flash off, select the lightning bolt in a circle with a diagonal slash through it.
Full details are in the "Using Flash" section of the manual (page 29 in my copy) If you need a manual, you can download one at
http://store.polaroid.com/media/document/i1237_manual_EN20090730.pdf
The Flash will not work
1. Turn on the camera.
2. Set the camera to Still Image mode.
3. Press the Flash button to cycle through the flash settings and select the one you need.
The flash range: 3 ft to 6.7 ft (1 m to 2 m).
To find Find Flash button, see user manual or download it here
http://lv.diplodocs.com/jim/POLAROID/A500-_E
Can I use my Fun! Flash 640 digital camera with other software applications?
Yes, you can use your Polaroid Fun! Flash digital camera with many popular image-editing software applications. The Fun! Flash is TWAIN-compliant and comes with its own image acquisition software, which is automatically installed when you install PhotoMAX. Just open your image-editing software and select Polaroid Fun! Flash as your acquisition source.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
