SOURCE: how do I change the battery or batteries in a
Hello. The correct way to remove and replace the battery would be to unscrew the end cap all the way. The Battery will then fall away allowing for a new battery insertion. The "plate" is not suppose to be removed (according to Gerber Blades). Hope this helps.
SOURCE: how do you change batteries
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
SOURCE: How do you change the batteries on a Coleman
I got it off. All you need is pliers. You take pliers and twist the bottom of torch with them. It'll come off in a minute or two, just keep twisting!
In order for someone to help. We need more information, the manufacture name, the exact model number. Usually found somewhere on the device. That model number has to be the longest model I've ever seen. Maybe the LED is bad.
