SOURCE: baby einstein aquarium does not scroll
I had the same problem...call baby einstein customer service 1-800-328-0885 ext: 5 , they'll connect you to kids II- the company that manufactures the product for them and they should send you a replacement!!
SOURCE: my son has bought a deluxe starter fishing set for
you can put the weights on leaving about 3 feat of line then tie the hook on by putting some line through the loop in the hook and twisting it about 7 times upward and pulling the excess line through the bottom loop in the line. Or just attach the floater with a little bit of weight under it with the hook put on the same way.
SOURCE: since I moved to a
just like any other living things, plants and animals require certain conditions to thrive. for the fish it will be adequate food, enough air supply and room temperature. for the plant, adequate light and water is critical. you mentioned the acidity of the water, to be on the safe side make sure the PH of the water is neutral or near neutral at PH 7. if you meet all these conditions, your pet and plants should be fine. thanks
SOURCE: Ocean wonder aquarium motor not running
Sounds like the little motor that runs it has failed. I have had luck taking toys apart and getting a replacement motor at a hobby shop. They are very cheap.
SOURCE: Can aquarium lighting affect my fish's mood?
Proper aquarium lighting can influence your fish behavior and psychology (in a good way) and it is vital for the overall health and well-being of your entire aquarium.
There are some
limiting factors like the oxygen availability and the
filtration processing. I gave you some examples below they all refer for small
or large freshwater fish.
3 cm of adult fish length per 4 liters of water.1 cm
of adult fish length per 30 square centimeters of surface area. 1 inch of adult
fish length per US gallon of water. 1 inch of adult fish length per 12 square
inches of surface area.
Thank you Bill
