SOURCE: How to remove door panel to gain access w/out damaging panel?
I hope this helps , easier done than said :)
1- Remove door latch bezel. (handle)
2- You will find door trim panel retaining bolt , remove it.
3- Remove the door pull handle screw cover.
4- Remove the door pull handle retaining screws.
5- Detach the interior door trim panel ( to make removal easy , release clip by lowering glass and pressing case inwords)
6- Disconnect the door trim harness electrical connector.
7- Remove the door trim.
8- Disconnect the driver door module electrical connector
9- To install , reverse removal procedures
Testimonial: "Project completed. Karaman is correct with the steps needed to remove and gain access to window. Thanks"
SOURCE: Jensen JE3208 does not come on
No. There is not reset, and the problem to your TV is of reset.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
