Cam is missing but machine looks like plain zigzag should work without it. Also, where to get manual for this machine
This video will probably be handy, although not quite your model, it should be very close. Generally, your machine should be able to do straight & zig-zag stitch without cams. Cams were usually for decorative stitches.
Kenmore 158 17550 Sewing Machine Tutorial
Parts: https://www.sewingpartsonline.com/kenmore-158-17600-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=64
Manual: Kenmore 158 manuals 3
SOURCE: My Kenmore machine sews a straight stitch fine for
timing issue, needs to be serviced and re timed.
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
SOURCE: looking for a free manual some parts for kenmore sewing machine model C877.06
try these sites for parts & manual
sewusa.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
SOURCE: why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
