SOURCE: Needles keep breaking
Sew paper.If ok try buying from reputable Haberdashery packets come in various sizes. Maybe material is to thick for needle
SOURCE: do you have an illustration
You can get a pretty detailed instruction/manual here for the FY5318. http://www.feiyueusa.com/Manual/92966.pdf
The 92966 is the FY5318 sold through Harborfreight.com
SOURCE: Needle won't move
Make sure the clutch motor is powering up. make sure voltage toggle switch is on 110v and not 220v. Also rotation set correctly. Independently, make sure the motor runs. With your hands and motor belt disengaged, attempt to turn the handwheel toward you. If it is moving, then make sure motor is running. It handwheel does not turn it could be the machine. Make sure the stitch length dial is set at 2 or 3 and not 0 or 5. That could be that problem as well.
SOURCE: needle keeps breaking the top thread...
In general, there are three main causes for this...
wrong needles (Singer), low quality thread (dual duty or all purpose), incorrect threading. Be sure to thread the needle from front to back.
SOURCE: embroidery machine needle breaking
make sure your top thread is feeding properly and not catching on the spool or twisting as it comes off the spool. When i use metalic thread, i put it in a small can beside my machine and it works great.
