Do you see any other digits alternating with the E4? Most of the error codes that I know with Samsung split system air conditioning units have three digits after the E. Depending on the last two digits, the error could be with the control board (printed circuit board), the fan, a sensor connected to the control board or the wiring. See https://removeandreplace.com/2017/08/15/samsung-split-system-air-conditioning-ac-error-codes-and-troubleshooting/ for some ideas.
I found the User Manual for the Samsung AQV24TWDN here: https://www.samsung.com/au/support/model/AQV24TWDNXSA/ . Scroll down or use the Download User Manual link. The direct link to the manual is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_AU&CttFileID=5078406&CDCttType=UM&ModelType=N&ModelName=AQV24TWDNXSA&VPath=UM/201401/20140107175828476/Australia_AQV30T@_IBIM_33367A_E_1.29.13.pdf&OriginYN=Y .
Please add a comment with the full error code for your air conditioner.
SOURCE: changing from air conditioner to warm air dont have a manual
you will need to open the flap of the remote and press the button on the bottom left hand corner with a triangle, snowflake, raindrop and sun. Note on the top part of the LCD screen will be a sun. This indicates heating. Then set temp and fanspeed.
I take the time to help and answer your question so please rate me
Thankyou
Mat
SOURCE: reset air conditioner samsung aqv12msan
http://nodevice.com/user_manual/samsung/other4/aqv12msan.html
Go to this web site. It has a copy of a user manual. May get the answer to your question as to how to reset.
Hope this does it for you.
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
SOURCE: samsung Quietside model QScc241 the read out says E4 what is that reading for
need more details , read out where , on stat ?
SOURCE: WRAC has E4 on display
If the return air sensor not defective you must check the refrigerant charge . may be you have loss of the charge and you have to charge the unit and check it for leakage .
