Ayodele AYO-SOLOMON Posted on Jul 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED THE POWER BOARD OF MODEL :HT-TZ315 SAMSUNG HOME THEATER. THE POWER BOARD....CAN ANYBODY HELP?
Mark Cheong
Level 3:
Master:
  • Samsung Master 791 Answers
  • Posted on Jul 19, 2018
Mark Cheong
Samsung Master
Level 3:
Master:
Answers
791
Questions
0
Helped
476202
Points
2475
Try; https://www.samsung.com/uk/support/model/HT-TZ315R/EDC/
* USA; https://www.samsung.com/us/#
Aloha, ukeboy57
Additional repair info;
* THX23 power supply (technical); https://www.youtube.com/watch?v=pM1mgs1yBBc
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Oct 15, 2007
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
A
Anonymous
  • Posted on Aug 02, 2008
SOURCE: comcast remote and need code for a samsung ht-tq85 home theater
http://www.ehow.com/how_2116903_easily-program-comcast-remote-control.html
Anonymous
  • 3 Answers
  • Posted on Nov 04, 2008
SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems. Swapnil
dblackmon7
  • Posted on Dec 01, 2008
SOURCE: Durabrand Home Theater Manual
You can download the manual from www.retrevo.com and enter lenoxx ht-3917. This is the company who actually makes this item. I needed the same thing. I searched for hours on the web and found out that Lenoxx is the manufacturer. They are out of business but you can get the manual from there.
Anonymous
  • Posted on Oct 18, 2009
SOURCE: samsung ht tz315 unlock code
I saw your question about the unlocking of samsung ht-bd1250. I also would like to unlock mine, which is zone 1.
Do you know how is it possible?
I saw many times that a code should be entered thru the remote, but just after powering on the player?
Thanks for your help
Samsung home theatre ht tz315 shows
Clean the rear panel fan. It is probably dirty.
Manual for samsung dvd home theater system model HT-Q40
Your Quick Guide and User Manual for the Samsung HT-Q40T/XAA may be downloaded here.
Blown resistor and IC
R91 is a 1K Ohm
M1 is FSDM0356
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Removal of region codes
PRESS KEY " ENTER 84269 ENTER "
6helpful
Samsung HT-TWZ312 surround sound probs
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Samsung ht-tz315 subtitle character problem
Hi Old man
You're going to be in trouble. Beware.
18helpful
3answers
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
11helpful
7answers
Samsung ht tz315 unlock code
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote
Press Enter on the remote
Press 8, 4, 2, 6 and 9 on the remote
The player will power Off
Switch On power from remote
does not work
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
