Https://printcopy.info/?l=en&mod=erc&brand=Canon&model=MF4410&code=E301-0001
Canon MF4410 Error Codes
Quoting:
Code
E301-0001
Description
Insufficient light intensity in shading
Remedy
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor.
(4) Replace the Main Controller Board.
SOURCE: Error 99
I experienced the same problem ( Err 99) on similar set-up after taking around 9000 shots. I have read solutions from upgrading firmware to 2.0.3 and extensively cleaning the gold contacts on the camera and the lens with alcohol. Since my firmware is already ok, then I think the cleaning did the thing.. my camera does not randomly give the error anymore!
SOURCE: Error E22 in my MP145
Error E22 = Carriage error
to reset this error follow the steps below--
with the printer powered off but connected to a power source , you must:
1. Press stop/reset button, and then press [ON/OFF] button to restart
2. Press [ON/OFF] again and then press twice the stop/reset button.
3. Press [ON/OFF] & Stop/reset button together, this time to enter the repair status and power lights will be green,
4. Press stop/reset button 4x and warning lights will be go out in [ON/OFF]button.
5. Turn off the printer.( it must be turn off) and then turn it on again.
Use with your own risk ,
i’ll try this way and my Pixma MP145 not blink again.
The number of the Reset button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5 Unplug cable power. (for MP145 / MP150)
6 Turn Off Power. (for MP160)
Note if the above steps did not work's means you need to check your Carriage;
Hope this helps...
Good Luck!!!
SOURCE: canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Try this: 5b00 error press MENU button, SCAN button, COPY button, SCAN button.
wait a minute.
it may be enter into special mode: service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
Thanks, Joe
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
