Plumbing Logo
M
Marjorie Lynne Lynne Porterfield Posted on Jul 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clean the filter in the spray head in my cuisinart kitchen faucet? The hard spray works fine but regular spray seems to be blocked.
Andrew Bugbee
Level 2:
Novelist:
Champion:
  • Expert 267 Answers
  • Posted on Oct 03, 2018
Andrew Bugbee
Expert
Level 2:
Novelist:
Champion:
Answers
267
Questions
Helped
168765
Points
403
Place the spray head in vinegar for an hour or so. This should dissolve any scale that may be keeping it from working properly. Good luck!
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 05, 2008
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 09, 2008
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
kachbibi1
Bill Dickerson
  • 979 Answers
  • Posted on Mar 04, 2009
SOURCE: Low flow from Kohler K15160 spray kitchen sink
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Bill Johnson
  • 306 Answers
  • Posted on Jul 31, 2009
SOURCE: I have purchased a Tuscany Brass kitchen faucet
if i remember correct this connection is plastic to plastic,if this connection is broken you must replace the hose and the head.i hope this helps.good luck with you project.
Anonymous
  • Posted on Oct 30, 2010
SOURCE: i have Geyser Kitchen Bar Sink/ Spray Faucet and i...
I have a Geyser GF8 that also leaks at the turning joint. Anyone know how to dissamble one of these faucets?
How do I get more water pressure from a Tuscany model 673-6070 kitchen faucet?
Remove the spray head and clean the filter screen it may have particles of mineral from the plumbing clogging it.
Nov 26, 2016 • Plumbing
Price pfister ashfield f-529-myp
leave the screen out something is restricting the flow at the screen or take guts out of aerator and keep screen some have flow restrictors that may get clogged usually a plastic disk
Blocked spray head filter
Could you show us a picture of the spray head?
1helpful
Faucet is running slow
I think that there is a screen in the inlet side of the spray head, the hose just unscrews and you can rinse the screen out with the water coming from the hose
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
I have a kitchen faucet by hansgrohe, 06801860. When I turn on the water, some of the spray comes on, when I press for the spray, a thick stream of water comes in the center. I would love to have spray...
your sprayer ''picks up''it's supply from the flow to your faucet.spray heads wear out & are not repairable.replacement hose & sprayer assembly can be found at home improvement stores.if you can see the other end of the hose where it attaches to the faucet,it's not too hard to replace.you don't have to turn off the water at the meter.
Sep 22, 2009 • Plumbing
Delta kitchen faucet mixed spray...diverter problem???
Delta Faucets
3helpful
Problem solved.
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
