Mayo Property Posted on Jul 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i connect a konica 7115 printer to a network
Norman Weimar
Level 3:
  • Konica Master 7,035 Answers
  • Posted on Oct 14, 2018
Norman Weimar
Konica Master
Level 3:
Answers
7035
Questions
Helped
1913841
Points
11960
That is a legacy machine from Konica before it was konicaminolta doubt you can get drivers for it
3 Related Answers
Anonymous
  • Posted on Mar 12, 2008
SOURCE: konica photocopier 7115 with error code (cof32)
Check out this post
http://smarka.com/members/boards/content/CTmessages/46344.htm
Anonymous
  • 145 Answers
  • Posted on May 02, 2010
SOURCE: MY KONICA 7115 COPIER HAD DISPLAYED ERROR C05 00
turn off the machine and hold down the STOP botton while turning on the power .hold for 5 seconds .
than should reset the code .if the code pressist that you have a bad thermester in the fusing unit.
good luck
Anonymous
  • 32281 Answers
  • Posted on Jul 28, 2012
SOURCE: Network a Konica Minolta printer
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5.Right click on the printer - click Properties - click Print Test Page toconfirm printer installation.
I have a KONICA MINOLTA bizhub 7115, but I do not know the code developer (ATDC - auto adjust), please let me know. thank you
Has the developer been replaced? do not run this auto adjust unless that has been done. 36 mode will get to auto adjust.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How can i solve error code C0F32 in konica miniolta 7118
Press [Utility] -> [Stop] -> [0] -> [0] -> [Stop] -> [0] -> [1]. Go to [Adjustment] --> [ ATDC Adj. ] [Start], wait for 2 mins. it will automatically stop then turn Off / On copier. If C0F32 appear replaced the ATDC sensor located under the developing unit then calibrate again.
Konica 7115 problem maintenance
what about the maintenance of this machine
My problem is with a bizhub 181, because the copies are opaques. I already check and replace the imaging kit. but is damaged.
Sir/Mam,
Is the machine set up as a printer also do print come out ok? Copies from the big glass ok? Mite be the electrical connection to the sponge roller on the right side door the sponge looking roller is what helps the transfer of the image off the drum to the paper. The paper is guided between both the drum and that sponge looking roller to place the image on the paper. There is a high voltage applied to that roller during the copy cycle. the connection for the roller is on the copier at the rear where the right side door closes
1helpful
I have Printer refill powder in plastic bag, can i use it to refill some printers catridges or i need machine to make refill ink?
whats the model no of the machine? ink and toner are 2 totally diffrent things one is a powder and other is a liquid
2answers
Wrench symbol on Konica 7115 means what?
PREVENTIVE MAINT. Replace drum, cleaning blade,developer etc. comes as a kit for the technicians to replace, clearing counter without doing things not good machine uses the counters to adjust voltage on certain parts and is the only way it knows new parts installed clear counter and not replace parts causes codes and image problems
We have a Konica Minolta bizhub 250 All-In-One Laser Printer and somehow we disabled the network connection and now the printer doesn't allow any connection to it through the network cable even if
When the copier is on the network does the little leds flash at the network connection? ping the ip address of the copier what do you get.
Go into admin mode on the copier network setting what is your ip address, subnet and gateway reading did you replace a router? now the network is one system and the copier was never told this new info?
7helpful
2answers
How to fix error c0f32 in konica minolta bizhub 180
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Top Konica Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
NOEL
NOEL
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
