Question about GE WBVH6240F Front Load Washer
Shaking like crazy
I have a brand new GE front load washer and the first time we put it to work it started shaking and viberating like it was possessed. It literally vibrated 3ft outside the laundry room.
  • 2 more comments
  • lanternhill Mar 11, 2008
    I have the same problem with my front loader GE washer and GE will NOT stand behind it. The serviceman made it clear that he knows there is a design problem but he has to report that it is operating as designed. My advice is take it back if you can. My builder said it would damage my home. GE said I should have put my laundry room in my basement!
  • lindros2 Mar 18, 2008
    same problem - i'm infuriated.
  • Anonymous Mar 19, 2008
    I have the same problem. The wierd thing is it only occurs when I wash the bathrobes. I had a GE tech come in and tell me that the problem was occuring because it wasn't balanced. The next day when I did a load of wash the same thing happened again. I had another tech come in a few weeks later and he looked at it and ordered me a new tub and a bunch of other parts that they are installing this coming Friday. I will keep you all updated if this fixes my problem.
  • rexryder Apr 11, 2008
    Shaking, Have had repair men out balance is ok. Still shakes the whole house! Sheared floor underneath washer for better support. Helped but still shakes. Need a solution before it damages other items in my laundry room and home. I have the drawer that sits underneath it .
For the new machine that is violently shaking, make sure the shipping bolts in back are removed and their plastic pins.
For a machine that has developed this problem, it may be the shocks under the tub. these can wear out. but check level and balance first.
When it is on the pedestals the rubber shims are not supposed to be there, they are for dryer only.
Posted on Apr 19, 2008
Eat it
Posted on Feb 11, 2008
    Champion:
  • 249 Answers
ALERT. transit brackets still on machine ..REMOVE THEM;;
Posted on Nov 25, 2007
SOURCE:
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Can a front load washer be stacked on top of a front load dryer?
Normally, the front loading machines come with a special stacking kit (that may be available separately). Now I wonder why one would put the washer on top! Most of the time the washer is put at the bottom making it easier for plumbing. Secondly, in case of a large spill, it would be safer to have the dryer on top due to the power required for the heating elements. I would therefore not recommend putting the washer on top even if that might be possible to do so...
Oct 24, 2013 | Whirlpool Washing Machines
Washing machine is really loud when spinning (sounds like a plane taking off)and if you are sitting on couch one floor down you can feel the couch vibrate and the floor its on shakes like crazy. I was told...
no it is not normal and there so be no reasonable excuse for bad vibrations and shaking on a new machine ,if the setting up instructions and leveling procedures were carried out.
at six months it should be still under warranty so have it fixed under the warranty
Apr 23, 2017 | Maytag MHWZ400T Front Load Washer
Our new GE front load washer shakes/ vibrates and moves during the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Aug 22, 2010 | GE WSXH208A Front Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Shaking uncontrollably during spin
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer shakes, as if out of balance, after all water is drained
Biggest problem i get on the front load machines are spinning and draining problems. First thing to check is make sure your soap is not foaming up. If you see alot of suds in the machine when it is washing switch brands h.e. soap is best but he liquid tide has been a big problem with suds. Next make sure you put equal size items don't mix heavy and light items in machine as this may have off balance issues! Next check the coin and pintrap if it has one some machines have filters on the front of the machine that need cleaning.After these have been checked see if the machine has any unusual noises or odors when used rubber burning odor or electrical odor when in use may indicate a overloading or internal problem with the machine.
Oct 09, 2007 | GE WSXH208A Front Load Washer
GE WBVH6240F Front Load Washer Logo
373 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
