When you configure rate limit on S6720-54C-EI-48S-AC, the following configuration is recommended:
Set the CIR, CBS, and PBS values but not the PIR value. CBS = 200 x CIR PBS = 2 x CBS = 2 x 200 x CIR = 400 x CIR The CIR value is expressed in kbit/s, and the CBS and PBS values are expressed in bytes.
Set the rate limit for outgoing packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr outbound cir 10240 cbs 2048000
Set the rate limit for incoming packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr inbound cir 10240 cbs 2048000
SOURCE: How to Configure Rate Limit on Huawei Switch
It's different from configuring rate limit for Huawei S6700 and other Huawei Swithes. The article as below may help you for your question
Huawei Networking Products News and FAQ
SOURCE: How to Configure Rate Limit on S6700?
When you configure rate limit, the following configuration is recommended: Set the CIR, CBS, and PBS values but not the PIR value. CBS = 200 x CIR PBS = 2 x CBS = 2 x 200 x CIR = 400 x CIR The CIR value is expressed in kbit/s, and the CBS and PBS values are expressed in bytes. Set the rate limit for outgoing packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr outbound cir 10240 cbs 2048000Set the rate limit for incoming packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr inbound cir 10240 cbs 2048000 S6700 Switch Thunder link com
SOURCE: How to Configure Rate Limit on S2700&S3700&S5700?
Ā· Set the CIR, CBS, and PBS values but not the PIR value.
Ā· CBS = 200 x CIR
Ā· PBS = 2 x CBS = 2 x 200 x CIR = 400 x CIR
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] qos lr outbound cir 10240 cbs 2048000
[HUAWEI-GigabitEthernet0/0/1] qos lr inbound cir 10240 cbs 2048000
NOTE:
A traffic policy can be used in the physical interface view, Eth-Trunk interface view, and VLAN view.
ES5D21VST000 is a stack card that provides two QSFP+ optical ports for stack connection, can be installed in the rear card slot of the S5720-C-EI and S5720-PC-EI series chassis.
