Question about La Crosse Projection Alarm Clock with Temperature and Humidity Display
Remote signal not received by Shift 3 projection alarm clock
I have a new Shift 3 Time and Temperature Alarm Clock. The remote signal is not being received by the clock..hence the outside temperature is not recording.
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
Posted on Nov 14, 2009
Light that provides projection and on the clock face is not on. Batteries changed didn't solve the problem. If there is a need to unscrew and remove the back, I'll have to buy a supper small jewelers phillips head screw driver. (???).
V. Romiti
Posted on May 04, 2011
SOURCE:
Cannot set time
WWVB Radio Controlled Clocks
www.nist.gov/.../radioclo...
National Institute of Standards and TechnologyFeb 11, 2010 - To find out more about WWVB radio controlled clocks, please ... Before it does so, it applies a time zone correction, based on the time zone setting that you ...your radio controlled clock, but we cannot provide technical support ...
[PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ..... The alarm time setting cannot be changed if ALARM.
[PDF]Atomic Analog Wall Clock - La Crosse Technology
https://www.lacrossetechnology.com/.../Generic_Headway_Manual_050...
clock is synchronizing to the WWVB signal and once the radio signal is decoded, the hands will ... trouble free. If the clock receives a clear time signal, it will set itself perfectly. ... A: No, the clock cannot work with a booster antenna. Opening the ...
ICF-218 Sony Alarm Clock - YouTube
? 1:50
https://www.youtube.com/watch?v=XTQ8zEMMNq8
Aug 4, 2012 - Uploaded by sohvintage
Jan 10, 2016 | Audio Players & Recorders
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
Jan 17, 2011 | Audio Players & Recorders
Shift 3 projection alarm clock cannot connect with the remote
Did you put two AAA batteries in the remote? Use a small phillips to take the cover off of it. Then hold channel on the main unit for three seconds to synch it with the remote.
Mar 14, 2009 | La Crosse Projection Alarm Clock with...
Where to put outside remote
If you have storm windows, put it between the window and the storm window.
Or try just below the overhang of your house.
Mar 01, 2009 | La Crosse Projection Alarm Clock with...
Shift 3 Projection Alarm clock remote cannot open
Once the batteries are installed in the remote the temp will appear in the LED screen. Now you are ready to link signals between the main unit and the remote. Simply remove one of the two triple A batteries from the main unit and then replace. You should then see what appears to be a flashing object shaped like a kite with a tail while the two units link up. Then you should see the temp reading at the remote appear in the LED readout at the main unit. By the way there is also a very small reset at the top of the switches on the back of the main unit that can be depressed with a SMALL pointed object like a scissor point or safety pin point.
Feb 06, 2009 | La Crosse Projection Alarm Clock with...
Temperature sensor
I have this clock and just finished getting it all working again. At first I kept messing around with the AAA batteries in the remote unit, finally realized there were AA batts in the back of the main clock/display unit. Replaced those, pressed the reset button next to the battery compartment. Pressed the reset button on the remote unit (it's under the back lid next to the AAA battery compartment). Little red light on the remote unit started flashing and remote temp showed on the main display. Then you have to wait for atomic time to reset itself or set the time and other display options manually - I kept messing around with the various buttons until I figured out how to do this (atomic time never reset) - start by holding down the smaller "AL" button on the top next to the big snooze/light button, use top two side buttons for up/down, use the AL button to go to next setting.
Aug 15, 2008 | Honeywell RC182WR Atomic Alarm Clock - Red
Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Nov 08, 2007 | Audio Players & Recorders
La Crosse Projection Alarm Clock with Temperature and Humidity Display Logo
474 people viewed this question
Top La Crosse Audio Players & Recorders Experts
Steve Allison
Steve Allison
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
